 Interesting Ghia information
the aussie trimmer
the aussie trimmer
Interesting Ghia information  Empty
MessageSujet: Interesting Ghia information    Interesting Ghia information  Icon_minitimeMar 7 Sep 2010 - 9:14
"The painted metal dash top was covered with a Ribbed Padded Dash top from 2 252 435 or 2 261 049 or 2 257 979 (!)
A VW manual states 2 261 049"
"the Plastic Waffle Sun visors were replaced with the Padded Waffle Sun visors (couple of dates again: VIN 2 252 435, or
19 - 20.January 59)"
So both these updates happened at a very similar time, if not exactly the same time all Jan 59
The way I read it, the seat frame from July 55- October 55 had the thin back a non adjustable hinged backrest frame, the seat covers (in some early cases the lower backrest bar was split to accommodate the fixing of the backrest cover like the early VW seat covers it was changed again to a tube with the spear tags to hold the covers) and door panels were all leatherette (there is a hint that the door panel top part did have a rear direction diagonal stitch pattern but was later changed to the horizontal stitched lines) and part rubber part carpet bulkhead covering small panels smoothed out the bulkhead lines over the heater pipe to the dash windscreen demister.
In January 56 the lower part of the seat frame was replaced with an adjustable screw type backrest mechanism, (there was some attempt in October 56 to stop the fracturing of the seat frame for the 57 frame and when they went to the 58 and 60 years they increased the length of the reinforcement so it was further into the slider channel area.) the P200-205 corduroy cloth was also introduced to help the export market and the seats were still thin-back up to September 57 when the new inclusions for the 58 year model came into play.
These included the replacement of the early backrest adjuster with the VW 3 position backrest adjuster attached to the cushion frame and the VW pivot leg on the backrest frame to allow better access to the rear seat and luggage area. Rear emergency seat on the Coupe had a 108 cm backrest and a 104.5cm width cushion these sizes were then reduced for the Cabriolet models to 91 cm backrest and 88.3 cm for the cushion, to accommodate the cab intrusion of the folding top frame.
With the change from thin-back to 58 thick-back the frame stayed the same only the spring pad and padding was upgraded with the introduction of the new leatherette and P206-209 square weave cloth inserts material.
Other changes at that time were; carpet replaced the felt covering in the luggage compartment behind the rear emergency seat, full rubber bulkhead covering that accentuated the heater pipes, 2 types of plastic materials with up swept design, 3 chrome mouldings and new thin passenger armrests on door panels.
Seat frame changed again September 59 (60 year model) to a smaller more rounded cushion shape and the replacement of the lower protruding horizontal bar with a much less protruding bar. With the inclusion of the 3 horizontal metal rods to hold the separately covered rear backrest panel, new cushion spring pad and padding was also introduced, both doors now have plastic armrests on both sides but still retain the up swept waffle door panel design.
This changed at the beginning of the 61 year model when they introduced the fine ribbed vinyl on the upper and lower parts into the door panel covering and the P210-213 Hounds tooth insert material.
Please correct me if you have any more information
http://www.trimtec.com.au
MessageSujet: Re: Interesting Ghia information    Interesting Ghia information  Icon_minitimeMar 7 Sep 2010 - 19:47
kevin I'll reply to your post in french, because it is easier for me and members of the forum.
Oui le dash pad arrive bien au châssis 2 261 049 (Janv 59) selon les manuels VW sur la karmann.
Par contre la modification du tableau de bord arrive quelque mois avant (Nov 58).
Donc il y a bien des low light avec le nouveau tableau de bord mais sans le dash pad entre Novembre 58 et decembre 58.
La bande de retenu en métal (en dessous du dash pad) arrivera bien plus tard (début juillet 59)
"the Plastic Waffle Sun visors were replaced with the Padded Waffle Sun visors (couple of dates again: VIN 2 252 435, or 19 - 20.January 59)"
Suivant mes documents le changement des pare soleil se fait bien au châssis 2 252 455
Difficile de dire les premiers changement entre aout 55 et décembre 55 car il n'existait pas de manuel karmann a cette époque, et il y a très peu de note sur l'evolution durant cette période. Mais les sièges avant ont bien un dossier réglable en aout 55 (voir le plus vieux karmann du monde encore en circulation body number 39)
.... (there was some attempt in October 56 to stop the fracturing of the seat frame for the 57 frame and when they went to the 58 and 60 years they increased the length of the reinforcement so it was further into the slider channel area.)
Oui il y a bien une renforcement de l'ossature des sièges en octobre 56 , et les nouveaux siège (avec nouveaux réglage du dossier) arrivent au châssis 1649253
Faux , l'ossature des sièges changent à nouveau en aout 60 (année modèle 61) avec les trois tubes rond horizontal dans le dossier de l'ossature du siège (et pas pour l'année modèle 60)
the aussie trimmer
the aussie trimmer
MessageSujet: Re: Interesting Ghia information    Interesting Ghia information  Icon_minitimeMar 7 Sep 2010 - 23:01
Thank you for your clarification to my Ghia information, Cyril. This is the very reason I posted this information, to provoke a response to help me compile and confirm the correct information and I knew I would get that from this forum. With France being closer to the point of manufacturer, I believed that you would have more and more accurate information than anyone else in the world and I need my data to be as correct as I can get it.
Thanks again.
Merci pour vos précisions à mes informations Ghia, Cyril. C'est la raison même que j'ai posté cette information, de provoquer une réponse pour m'aider à établir et confirmer les informations correctes et je savais que je recevrais de ce forum. Avec la France est plus proche du point du constructeur, j'ai cru que vous auriez des informations plus précises et plus que quiconque dans le monde et j'ai besoin de mes données pour être aussi bon que je peux l'obtenir.
Merci encore.
MessageSujet: Re: Interesting Ghia information    Interesting Ghia information  Icon_minitimeMer 8 Sep 2010 - 21:00
Le dessus de tdb en metal etait recouvert d'un garnissage cotelé de 2 252 435 or 2 261 049 or 2 257 979. Un manuel VW mentionne 2 261 049
Les pare-soleil gaufrés ont ete remplacés par ceux garni (: VIN 2 252 435, 19 - 20.January 59)"
Donc ces 2 modifications sont apparues a un moment simultané, quasi dans le meme mois de jan 59
De la facon d'interpreter la doc, les fauteuils de july 55 a october 55 ont un dossier fin et non ajustable a la charniere. la housse de siege (pour certains cas des plus anciens, la barre de dossier basse etait partagée pour accomoder la fixation de la housse du dossier comme les housses des VWs anciennes il a ete changé par un tube avec des pics soudés dessus pour tenir les garnitures) et les panneaux de portes tout en simili (il y a un detail ou le haut du panneau de porte a un pli cousu en forme de diagonal vers l'arriere mais a ete changé plus tard par une couture horizontales) "La suite concerne les ajustements de l'habillage du tablier sous le tdb et plus particulierement l'arrondi que prend la moquette/le caoutchouc quand il passe au dessus du tube vertical de désembuage" (je n'arrive pas a cerner la nuance de son explication).
EN janvier 56 la partie basse du chassis du fauteuil a ete remplacé par un une vis ajustable qui assure le reglage du dossier. (il y a eu des tentatives en oct 56 de stopper le fracturing du cadre du siege pour le modele 57 et quand VW alla vers les modeles 58 et 60 VW agrandit la longueur du renfort donc il etait plus vers la zone ou le coulissant passe). le tissu P200-205 etait egalement introduit pour favoriser l'export et les sieges etaient toujours avec dossier "fin" jusqu'a sept 57 quand le modele 58 pris le relais.
Cela inclu le remplacement du premier dossier ajustable 3 positions fixé sur le cadre du coussin et le pivot VW sur le cadre du dossier pour permettre un meilleur acces a l'arriere de l'auto et a la male arriere de bagage. La banquette arriere (ndr- Kevin précise "emergency Interesting Ghia information  Icon_lol ) sur les coupés le dossier fait 108cm, 'l'assise 104.5cm, ces dimensions etant réduites a respectivement 91cm et 88.3cm pour les cabs, pour pouvoir le repliage de la capote.
Pour les fauteuils avant, avec le changement des dossiers "fin" vers "epais" en 58, le chassis reste le meme seulement le cadre a ressorts et le garnissage a été amélioré avec l'introduction du vinyl facon 'diamant' P206-209.
Les autres changements a ce moment (ndr- je ne saisi pas de quelle période il parle) ont été, la moquette remplacant le feutre dans le compartiment a bagage arriere. l'ensemble de l'habillage sous tdb fait en caoutchouc accentuant les 2 tubes passage de chauffage, 3 moulures chromées (!!!), et un accoudoir sur le panneau passager.
Le cadre des fauteuils change encore en sept 59 (année 60) vers un coussin plus arrondi et le remplacement de la barre horizontale protubérante du bas par une moins protubérante. Avec l'ajout de 3 axes horizontaux pour tenir la partie séparée de l'arriere du panneau de dossier, de nouveau ressorts de coussin et garnissage arrivent, a la fois les portes ont un accoudoir en plastique des 2 cotés mais toujours reprenant le design de la partie supérieure de l'habillage du panneau de porte.
Cela change au début modele 61 quand VW introduit le vinyl fait de tres fines côtes sur la partie supérieure et inférieure du panneau de porte et le materiau P210-213 dit "croc de chien"
MessageSujet: Re: Interesting Ghia information    Interesting Ghia information  Icon_minitimeMer 8 Sep 2010 - 21:20
Chris merci pour la traduction Very Happy
Kevin les pares soleil en plexiglas fumé sont remplacé par un nouveau modèle au body number 22922, VIN 1 649 253
the aussie trimmer
the aussie trimmer
MessageSujet: Re: Interesting Ghia information    Interesting Ghia information  Icon_minitimeMer 8 Sep 2010 - 23:18
Yes, thank you again Chris. I'm glad I am getting the support of 2 very informed Ghia people, willing to share their information and help. And thank you Cyril, I’m assuming that you mean the early green plastic visors of 55-57
Oui, je vous remercie à nouveau Chris. Je suis content que je reçois le soutien de 2 personnes Ghia très bien informés, disposés à partager leurs informations et l'aide. Et je vous remercie Cyril, je suppose que tu veux dire le début des visières en plastique vert de 55-57
Interesting Ghia information  55_ghi10
Interesting Ghia information  Asi20010
Interesting Ghia information  Asi20011
Just a couple of samples of the visors I can remake
Juste un couple d'échantillons de la visière que je peux refaire
MessageSujet: Re: Interesting Ghia information    Interesting Ghia information  Icon_minitimeJeu 9 Sep 2010 - 7:11
traduction remodelée. C'est fait ! Interesting Ghia information  Icon_wink
MessageSujet: Re: Interesting Ghia information    Interesting Ghia information  Icon_minitimeJeu 9 Sep 2010 - 8:18
Chris merci pour la traduction Interesting Ghia information  Icon_biggrin
j'avais mal traduit, il parlait du modele dit "gauffré" (modele 58-59). Il n'a jamais précisé ces modeles plexi vert en fait applicable comme tu le précises.
MessageSujet: Re: Interesting Ghia information    Interesting Ghia information  Icon_minitimeJeu 9 Sep 2010 - 17:42
Yes Kevin the platic visors are replaced by the Plastic Waffle Sun visors to the chassis 1 649 253 body number 22922,
The Padded Waffle Sun visors replaces the plastic Waffle Sun visors, from chassis 2 252 455
kevin I have already mentioned your sun visors reprodution on the forum. The product is really splendid Interesting Ghia information  Icon_cheers , as your trunk liner
Pour ceux qui sont intéressé par un carton de coffre vous pouvez jeter un oeil sur le web site de kevin, vous retrouverez une photo de mon coffre avant avec le carton de coffre que fabrique Kevin.
Oui cette partie la je l'avais bien compris Chris Interesting Ghia information  Icon_biggrin . J'ai rajouter cette information supplémentaire pour préciser la transition entre le 1er modèle de pare soleil et le 2ème modèle
C'est la partie suivant qui etait moins clair pour moi. Merci pour ton aide Chris Interesting Ghia information  197301
» information anguille
» Besoin d'information!!!!!
» Information Voyageurs (S.A.E.I.V)
» Recherche information sur la seine et la marne en région parisienne
» 23 sept 11 : réunion d'information TVA à Tomblaine
