 KG 70 ex helmut
the aussie trimmer
MessageSujet: Re: KG 70 ex helmut   Jeu 2 Sep 2010 - 23:04
No, the early models did not have this felt in the roof. But as the factory realised the value of such insulation, they included it on all there models, Beetle, Karmann and Bus. I know that if owners want to be pedantic about what was, or was not original on there cars build year; they could hesitate to include this insulation, this is a personal choice. But as it is not visibly evident when looking at the car and would add to its comfort, then why not include it.
We use a lot of modern parts and materials that were not used in the building of these cars, modern paints and fillers etc, so why not enhance the finish of the restoration and the comfort of the car by including some of these products now.
I am a purist in what I do, but also I'm a realist because I can see the benefit in using modern products to make the car and its restoration better for the future without compromising the original look.
Voir le profil de l'utilisateur http://www.trimtec.com.au
vesty
MessageSujet: Re: KG 70 ex helmut   Ven 3 Sep 2010 - 7:28
salut mec,
pour l avoir vu en vrai, il est tres beau
te connaissant il va surement avoir une tres belle finition
MessageSujet: Re: KG 70 ex helmut   Ven 3 Sep 2010 - 7:31
Pour résumer. Meme si Kevin reste un puriste dans ce qu'il fait, il reste réaliste. Tant que cette tibaude ne se voit pas, pourquoi ne pas la mettre tant qu'elle est invisible et que surtout elle apporte du confort.
Pour autant, il ne répond pas a la question de GHIA Wink
For Kevin. Indeed this is to enhance global confort. No doubt on the fact this is not in contradiction with purist doing attitude, but if you know could you please answer to GHIA question please ?
thanks for your great support.
regards
the aussie trimmer
MessageSujet: Re: KG 70 ex helmut   Ven 3 Sep 2010 - 8:57
regards
Hello again Christophe, it has been a long time since we last corresponded, hope you are well.
I’m sorry; I do not have a definitive answer to offer you, or the forum community. I do not actually know exactly when Volkswagen introduced this insulation to their range of cars. But from my memory of dealing with the VW models over the years, I would think (as an educated guess) it was introduced in the early 59-60’s (I know the Australian beetle had a thin felt in its roof) and with this assumption in mind; I would feel that this insulation would have been used in all the models, as they are all linked.
I must admit, this knowledge is all based on Australian cars, as I don’t know what might have been included in the European or the US VW models. But I can not imagine that the VW factory would have insisted on insulation only in the cars that came to Australia. But it may have been fitted in Australia with other interior components as part of the Australian content requirement. (meaning these cars were part assembled in Australia)
stephann ghia
MessageSujet: Re: KG 70 ex helmut   Dim 5 Sep 2010 - 10:16
hier je me suis occupe de l electricite reste un peu de taff a ce niveau la
j ai peint le chassis en noir anti rouille 2eme couche ( la premiere a ete passe l annee derniere avant de partir en peinture)
montage de la gache de capot avant joint de capot arriere des ampoule arrieres nettoyage de mon levier de vitesse sport
place au tofs
[img][/img]
[img][/img]
[img][/img][img][/img]
MessageSujet: Re: KG 70 ex helmut   Dim 12 Sep 2010 - 17:58
on a l'impresion qu'il est blaxonné!
stephann ghia
MessageSujet: Re: KG 70 ex helmut   Ven 15 Juil 2011 - 9:33
je deterre le post je mettrai des photos ce soir de l avancement du kg
stephann ghia
MessageSujet: Re: KG 70 ex helmut   Dim 17 Juil 2011 - 18:45
[img][/img][img][/img][img][/img][img][/img]
les dernieres pieces arrive dans la semaine si tout ce passe bien fin aout il fera ses premiers tours de roues Very Happy
MessageSujet: Re: KG 70 ex helmut   Dim 17 Juil 2011 - 19:05
sympa ce kg ,je viens de découvir ce post ,la couleur sort de ce qu'on voit habituellement et j'aime bien cette ensemble Very Happy
Dièdi
MessageSujet: Re: KG 70 ex helmut   Lun 18 Juil 2011 - 5:45
bonjour OLIVE il a bien avance c'est bien Wink
MessageSujet: Re: KG 70 ex helmut   Mar 19 Juil 2011 - 20:23
teintes et combinaison d'origine pour un 70 ?
je ne connaissais pas cela lui va bien
en tout cas enfin un 70 (enfin je dis ça je dis rien) Smile
Dièdi
MessageSujet: Re: KG 70 ex helmut   Mer 20 Juil 2011 - 6:06
stephann ghia a écrit:
Excellent!
Quel marron est-ce?
terra brown millesime 63-64
Wink pour kristoffe
stephann ghia
MessageSujet: Re: KG 70 ex helmut   Jeu 18 Aoû 2011 - 13:54
des news
j ai commence a poser la moquette et refabriquer les panneaux arrieres[img][/img]
[img][/img]
en paralelle j ai refait les panneaux et commencé la moquette pour helmut Wink
sinon je pars en week end en allemagne et demain je vais chercher mes pieces chez rudiger je ne me lasse pas d aller chez lui un stock de malade et des pieces exceptionnel Shocked
stephann ghia
MessageSujet: Re: KG 70 ex helmut   Dim 29 Jan 2012 - 19:40
voici des tofs de l avancement des travaux:
les panneaux de porte presque finis reste les baguettes en alu a poser (panneaux home made) j ai mis des baguettes sur les panneaux arrieres pour l'esthetique[img][/img]
[img][/img]
baguettes recuperer sur une golf 1 5 portes puis recoupé
les freins sont entierement neuf avec modification du tambour gauche car le pneu touchait l aile jantes 5.5+pneu 165 trompette longue et probleme recurant sur certains kg
tambour reusiné de 7 mm (5 a l interieur sur la collerette et 2 sur la face d appui)
MessageSujet: Re: KG 70 ex helmut   Dim 29 Jan 2012 - 20:32
Très beau rendu .
Bravo ! Wink
stephann ghia
MessageSujet: Re: KG 70 ex helmut   Lun 30 Avr 2012 - 8:18
les news du moment le kg est de retour en peinture {complete sauf le toit car l autre carrossier m a fait de la m.....}
le moteur est en prepa 1915 inside
j ai recu les derniere piece pour le remontage {reste les pcs a rechromer}
impatient de le recuperer
MessageSujet: Re: KG 70 ex helmut   Lun 30 Avr 2012 - 8:33
Tu as des "réactions" dans la peinture...non ??.....j'ai eu ce soucis, et mon père aussi: certains peintres trainent pendant des mois et finalement, bâclent le boulot en ne respectant pas les temps et températures de séchage.....après, ça bulle.... Mad Mad Mad
J'espère que la 2ème sera la bonne!!! Bon remontage à toi!!
stephann ghia
MessageSujet: Re: KG 70 ex helmut   Lun 30 Avr 2012 - 9:27
exactement ce qui m est arrive enfin pour la deuxieme peinture je ne suis pas du tout inquiet elle est entre de tres bonne mains
je mettrai des tofs des mon retour de vacances
stephann ghia
MessageSujet: Re: KG 70 ex helmut   Dim 13 Mai 2012 - 9:07
je l ai recuperer de peinture
remontage en cour[img][/img]
[img][/img]
content du travail realiser
stephann ghia
MessageSujet: Re: KG 70 ex helmut   Sam 19 Mai 2012 - 16:54
montage d une partie de l interieur
le fiston plus presse que le pere il s'y voit!!!![img][/img][img][/img]
MessageSujet: Re: KG 70 ex helmut   Sam 19 Mai 2012 - 17:35
ah oui il est fiére le fiston.
Mais il y a de quoi aussi. Wink
stephann ghia
MessageSujet: Re: KG 70 ex helmut   Sam 14 Juil 2012 - 18:57
quelques news du kg
en attendant de faire le 1915 j ai acheté un 1500 qui sera monté la semaine prochaine des que les toles seront revenus de l epoxy
les pares chocs sont chez le tolier pour le redressage et prendront le chemin du chromeur en fin de semaine prochaine
objectif sortie pour le bug show
stephann ghia
MessageSujet: Re: KG 70 ex helmut   Jeu 26 Juil 2012 - 10:53
voici quelques tofs [img][/img]mise en place du moulins
[img][/img]etat du coin arriere gauche avant passage du tolier[img][/img]et apres
je recupere les pc demain chez le chromeur et gros week end remontage
bugmanx
MessageSujet: Re: KG 70 ex helmut   Mar 31 Juil 2012 - 21:05
sympa d'avoir discuter de Kg
a bientot sur un meeting
Voir le profil de l'utilisateur http://forumkarmannghia.forum-actif.net/t3999-karmann-type-14-novembre-1967 http://www.ofadis.fr
stephann ghia
MessageSujet: Re: KG 70 ex helmut   Mer 1 Aoû 2012 - 13:27
on voit le bout du tunnel Very Happy [img][/img][img][/img][img][/img]
KG 70 ex helmut
